Login
Description
Typically, access is done through a web browser by entering the viewer address. This will load the viewer’s login page where you can enter the username and password.
Warning
This access is only relevant if the authentication method is qwc-db-auth or qwc-ldap-auth. If, instead, the authentication method is some type of SSO (Single Sign-On), the login is handled externally.
Fig. 1 Example login interface.
How to use
To enter the viewer environment, just click Access after entering the username and password.
